NewsW
Mar 01, 2012Explorer
blackeyed1 wrote:
Maybe I misread an earlier post regarding bio-diesel recommendation. Since I moved back here to Michigan, I will not use bio-diesel in my truck. I do use the cetane booster from Ford. I also keep an envelope in my glovebox with at least past 3 months of fuel receipts.
Ford specifies a maximum biodiesel blend content that can be used but do not require or recommend it.
Use more than that... and it is warranty void time if you have a problem.
Ford branded cetane booster is the way to go... sure safe vs. 3rd party brands.
Keep the receipts --- good for you... in case of trouble.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
