durallymax
Mar 02, 2012Explorer
NewsW wrote:BenK wrote:
Detroit still doesn't get it...
I am rather sympathetic to Ford because they were (as a company) traumatized by the 6.0 debacle.
When all the shooting is done, Ford ended up paying out a lot of warranty claims that should never have been paid.
Warranty fraud on the 6.0 was rampant.
It is not clear to me that the product ever made money for them.
As a result, Ford developed elaborate enhancements and procedures to cut warranty costs.
A lot of that is in the software that since 2008, closely monitor what the customer is doing, logging everything, and quietly feeds the data back to Ford every time the vehicle is plugged in to a dealer computer.
Don't believe me? Just read the manual from the 2008 and later models and note the explicit advice to owners that Ford is collecting data (and authorization).
As a result of the new enhancements, it can be fairly said that a majority of claims involving tuners, emission tampering, etc. have been denied --- fairly.
A Ford tech today, on any major warranty claim, have to spend hours not fixing --- but documenting the repair with a elaborate ritual that is intended to limit (not eliminate) warranty fraud and abuse.
The problem is, sometimes, this hard line approach can make a mistake --- where the customer is right, and Ford and the dealers buggered up.
That is what happened in some cases with the CP 4 pump.
Thats their own mistake in many ways. Every other brand of diesel truck gets misused just as much. Fords engine wasn't built to handle the added stress. The way they handled it caused a lot of bad publicity even though yes in the end Ford was right for denying a lot of customers claims.
GM went about it a different way, they never really put up a stink, but also never really had as many issues either. They also have no money so maybe they aren't the smarter ones. What they did on the new LML was install the new "feared" Bosch ECM that does not allow the calibration to be read through the OBDII port. In doing this, they were able to gain legal power against tuners and such because the only legal way for any tuner to be able to tune the truck would be for the truck owner themselves to pull the tune and then alter it, anyone else who would gain access to a tune other than the trucks owner would be committing fraud. They also put a hold on the ECMs for 6 months, and any replacement ECMs require a lot of documenting before being sent out.
Needless to say, there are a few programmers out there today for it. GM has their butt covered, and nobody is out bashing GM for not covering their warranty claims. They continue to be very good about replacing parts unless it is obvious the aftermarket part caused the failure. GM builds a good powertrain, so they don't have to worry about going broke with warranty claims like Ford seems to be. Look at how much the injector issue caused GM. GM themselves wouldn't deny modified trucks because they knew the issue lied in their product, the injectors. The injectors were Bosch, so did GM blame Bosch? Not entirely, they knew it was a joint failure, internal parts of the injector were part of the issue, and the other half were the systems controlling the injectors and the environment they were in. Speaking of which, I need to get back to replacing the set I am working on now.
blackeyed1 wrote:
Keep beating the horse, be it either alive or dead, until the truth comes out. I have a 2008 6.4L that is alive and well for now, but I'll never know for sure it stays that way. some of you think it's no big deal, but if Ford or my insurance denies repairs or payment based on this pump or fuel issues, I for one could not afford $10-12,000 for a new engine. I do the draining, filters, etc regularly per the diesel supplement. But there is a fear each day I take it out that it could be my last. Would you like that feeling? I doubt it.
I do have a back up plan should I have a catastrophic failure that my insurance or Ford will not cover. But I sure won't say it here.
The 6.4s use a completely different siemens system.
The CP4 pump itself is less than $1000 through GM.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
