Perrysburg_Dodg
Mar 02, 2012Explorer
NewsW wrote:gmcsmoke wrote:
For once I'd love to see you back up the false info you spew; show me a case or cases of HPFP failing on Gm's.
Link to the document below, provided to NHTSA ODI by GM:
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416387/INRD-EA11003-50068P.zip
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416382/INRD-EA11003-50069P.zip
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416383/INRD-EA11003-50070P.pdf
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416384/INRD-EA11003-50071P.zip
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416385/INRD-EA11003-50072P.zip
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416386/INRD-EA11003-50073P.pdf
http://www-odi.nhtsa.dot.gov/acms/cs/documentList.xhtml?docId=EA11003&docType=INV
Material above require (should read, would require or use requires. just saying :W) basic English and math above Grade 10 level to comprehend. was that really needed? BTW a third grader can make a clicky link. :W :B
Presumably, you think the same of GM who must have spewed "false info" to NHTSA.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
