ricatic
Mar 06, 2012Explorer
Huntindog wrote:FishOnOne wrote:rick83864 wrote:FishOnOne wrote:
Ford has a documented procedure for the techs to inspect different components of the fuel system including inspecting the filters for DEF comtamination. It's really a basic procedure that should catch any gross contaminants and/or owner neglect for maintenance.
Something like this?? C&P sorry I lost the link.
This is very important & somewhat controversial, but in being a believer that an informed customer is a better customer, I'm posting a portion of a publication that was recently made available to the Ford Technicians regarding fuel quality and the implications that poor diesel fuel quality/contamination has on the diesel high pressure fuel system. This is not altogether new news, however the implications are significant.
Engineering investigation into the impact of poor diesel fuel quality has determined that there are a number of fuel system related failures tied directly to poor fuel. The OEM Automotive industry appears to be taking a position that the Petroleum Industry and Fuel Distributors/Suppliers/Sellers must take control of the quality of the product (in this case diesel fuel) they are providing.
In short, please talk with your diesel fuel providers/stations/etc. where possible to discuss diesel fuel quality. The result of poor fuel is a very expensive repair (pump, injectors, lines and rails), the techs when there is an issue, will be visually inspecting components and comparing them with known failed components where root cause was fuel quality causing internal corrosion of the fuel system.
Fuel system contamination on 6.7L diesel engines can damage the fuel system components including the High Pressure (HP) fuel injection pump and fuel injectors. Engine operation on fuels and additives that do not meet the lubrication, cooling and anti-corrosion properties required by the HP fuel system components may cause symptoms including, but not limited to, the following:
· Crank No Start
· Long Crank/Hard Start
· Runs Rough
· Low Power
· Engine Knocking
· Exhaust Smoke
· Fuel Rail Pressure (FRP) slow to build
Follow the appropriate service procedure depending on whether the engine has been started with contaminated fuel, or not.
NOTE:
Failure to follow these procedures may result in fuel system and/or engine damage and may require vehicle warranty cancellation submission. Repairs required due to the use of improper fluids and fuel are not covered by the New Vehicle Limited Warranty.
NOTE: The most common sources of contaminated fuel are:
· Auxiliary vehicle mounted tanks
· Local storage tanks
· Other infrequently used fuel sources
· Refueling errors
The best action that can be taken to avoid concerns with the fuel system is to ensure vehicles are only fueled from sources with known quality diesel fuels verified to be free from water and other contaminants
It's called "prove it pal" or "gotch guy". JFYI Chebie is honoring there warranty.
Like I asked Ricatic... Where's GM's documented policy?
BTW remember that bad quality diesel can include diesel without the lubricity additive
And since there's alot of KookAid drinking going on here, put Dodge's documented procedure next to the KoolAid as well.
As a GM owner that has been following this closely from the begining....I can tell you that I have never seen a GM doc. like you are requesting. It may well not exist. If it does, it is not important as GM doesn't deny warranties like Ford does on HPFPs.
The Ford doc was actually posted by a Ford engineer some time before HPFPs became a known issue to the public.
GM has never posted anything like it on a public forum.
Ford also has other requirements that GM does not.
There is a paper that Ford wants signed at delivery (dealer follow thru is inconsistant) it states the need to drain the water seperator monthly, and strongly suggests the use of specific fuel treatments...Which are Ford products.
GM has no scheduled draining of the water seperator required, and actually discourages the use of fuel additives!
Not related to HPFPs, but Ford also require coolant testing at 15K.
Ford also seems to still be having trouble with radiators leaking.
GM has no radiator problems,,,,,and no coolant testing requirements.
It doesn't take a rocket scientist to see that the tone is vastly different between the two companys in terms of warranty coverage and ownership experience.
Ford takes a combative stance with their customers,,,even on issues that they know they have a problem with.
Gm wants their customers experience to be a positive one. They don't want their customers to feel like they are playing russian roulette every time they purchase fuel. Thus, HPFPs are covered.
No need to test coolant all the time. No radiator problems. If it happens it will be covered.
Huntindog
Thanks for taking care of my light work. Troy must be the FTE fan boy's new KoolAid mixer.
His standard line over there has been demanding information that has already been produced or does not exist in the form he approves. The diagnosis document from Ford was issued after my debacle with what one might call interesting timing.
I do not see the relevance of his demand for producing a similar document from GM or Dodge. The complete lack of any discussion regarding either GM or Dodge HPF system problems tells the story quite nicely.Dodge uses the well proven and reliable CP3 HPFP. GM used this pump until 2011. Bet they wish they had stayed with it.GM is now using the same marginally capable CP4.2 as Ford with very similar failure issues. GM fixes their CP4 HPFP failures under warranty. It is called Customer Service. This is beyond dispute but garners no respect from the Blue KoolAid drinkers. They prefer to drag out nonsense like the "Government owns GM so it is not GM's money" to shore up their lack of an argument.Dodge uses a diffeent pump with great reliability so their inclusion in the discussion is not germane.
The Blue KoolAid bunch ask for all kinds of irrelevant information to hide the basic facts of the situation. The fact is that the Bosch CP4 Series pump requires 460 Scar diesel fuel. Bosch has been publishing this specification for several years. They also participated in an announcement in September of 2009 with Siemens, Stanadyne and others that clearly outlines the longevity issues with HPFP's operated on diesel fuel with a higher scar rating than 460. They have published documentation that shows HPFP pump life to shrink to 1000 hours using fuel rated at 500 scar. They ignore the fact that US diesel fuel is standardized at 520 scar, well outside the published specifications from Bosch. KoolAid drinkers minimize Ford's decision to use the CP4.2series HPFP despite the fact that Ford violated a cardinal rule in design by forcing the use of a product that is at best operating in the sacred ground of "engineering margin".
All of the above comments are now well grounded in fact. Ford's answers to the NHTSA investigation prove the points. There is a significantly lower percentage of failures of Canadian Ford CP4 HPFP than their US brothers. It is not insignificant that the Canadian trucks are operated on the Canadian mandated 460 Scar fuel. It is not coincidence that the Canadian fuel matches Bosch's published fuel specification requirements.
Owners should not be required to provide the necessary additves to the fuel to raise the lubricity standards to the pump manufacturers specifications for long term HPFP success. Ford does not tell you when you buy the truck that it has a HPFP that does not meet US standards for fuel. They do not tell you that you need to run additive in the hope that it will protect the delicate HPFP. They will sell you a Ford additive, for additional cost to the owner and profits to Ford, that may raise the fuel specifications to Bosch's standards.
GM has taken the high road to customer satisfaction. With the known deficiency of the fuel standards and the growing number of failures, GM has stood tall behind it's product. They have repaired all of the Failed HPFP's under warranty. They will work out their problem with Bosch without asking the customer to pay the bill.
Ford has taken to the gutter in their trip to customer service. Their treatment of loyal customers is deplorable. After their last two diesel endeavors, they should know better.
Shame on Ford
Regards
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
