NewsW
Mar 06, 2012Explorer
FishOnOne wrote:
But the fact that Rick has began a crusade to cast as much negative publicity at every potential opportunity and when I would ask for specific documents/specifications/data from Rick he unfortunetly couldn't back them up
State in clear, plain english, what are you asking for?
What is your standard for "acceptable proof"?
Do you want to do this in accordance with FRCP?
ricatic wrote:
Troy
Good KoolAid...but you never answer the simple questions...ones that actually have the proof clearly defined.
In this instance you want a document that likely does not exist. You fail to understand why.
Is the public data GM gave to NHTSA not valid according to this Trojan?
A rule in evidence is production cannot be compelled for evidence that a respondent do not possess or have custody or control of.
If such a document is to be requested, the proper party is GM: go ask GM who is the likely party that has such a document to produce it --- if it exist at all.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
