FishOnOne
Mar 06, 2012Nomad
ricatic wrote:fishonone wrote:
I would be very surprised if GM's policy when reviewing a HPFP failure under warrenty is simply put the blind fold on and replace the HPFP and tell the customer sorry for the inconvience.
Just so you know we have 2 Chevrolet DMAX's in my family so I know how some of the issues were handled or not handled quite like you explain in your post above.
Troy
Good KoolAid...but you never answer the simple questions...ones that actually have the proof clearly defined.
In this instance you want a document that likely does not exist. You fail to understand why. The facts speak for themselves. GM is seeing Bosch CP4 failure in equal percentages to Ford. There is no discussion anywhere that indicates anything but GM's warranting of these repairs. Gm has not bothered to harass their customers with an inquisition, backed with a "look at this" document, when their HPFP fails...they just fix the truck.
Is that too difficult to understand?
Regards
I simply asked for the document (like the one the Ford techs use)the GM techs use to determine if a warrenty repair is covered or not based on your assumptions and you again cannot provide.
Taking the position that this document likely does not exist is pure speculation. But then again I'm not surprised of your response.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
