NewsW
Mar 07, 2012Explorer
hoopers wrote:
Somebody said it was a 0.6% failure rate. That means most of the pumps are working fine...99.4% of us should be fine! I hope it is this way!
The question is, lets index that rate of failure:
Mileage at failure.
And lets look at situations where there are repeated failures.
Yes, there are such cases on the VW site.
Then ask, is there something that is causing it to prematurely fail, will the failure rate increase with mileage?
Basically, is it .6 percent of total installed base (regardless of mileage) or is it rising percentage with age...
Need to do some back of the envelope work.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
