BenK
Mar 09, 2012Explorer
After zooming in on that image, think that the main feed from the pump to the
right side of the image is that bigger tube, along with a smaller tube that I
can't figure out...maybe that is a return line to the pump, as it seems to have
a compliant tubing from a dodad off the right side of that common rail...is that
the accumulator?
Then am pretty sure the left side is fed from the right side at the bottom of the
common rail...but...there are three much smaller lines in that grouping. Wonder
what the other two are?
Maybe part of the accumulator system?
the accumulator?
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
