durallymax
Mar 10, 2012Explorer
Below are some links to the LML fuel system that Henry posted up.
The Piezo injectors are fired from 160-240v @20amps according to the GM documents. Thats a lot of juice and is why you see the orange harnesses now on the duramax.
There is also a valve used to keep pressure in the return system which is supposed to aid in firing the injectors.
The CP4 pump is timed so that its pulses match up with injection events.
A pressure regulator is still mounted on the pump but an additional one was added to control how much fuel is bled off into the return system from the high pressure system. Essentially replacing the fuel pressure relief valve.
Fuel Routing
parts listing
Fuel Routing
parts listing
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
