BenK
Mar 11, 2012Explorer
NewsW wrote:
snip...
High enough pressure, and it will get through.
Ultimate PSI from the differential at the membrane...then consider tossing
heated, return fuel to a closed system.
That will increase the PSI inside the tank with the feed line back
to the pump creating a low pressure side of the membrane
Even creating a cycling PSI across that membrane dependent on the
tank cooling capacity dictated by the ambient temps around the tank
Need to know that membrane's PSI rating (range) is
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
