BenK
Mar 12, 2012Explorer
Another rat hole, though necessary, is with their H2O management systems and
components
Currently folks are commenting on the dissection of various filters.
That will lead to my next question...why doesn't it work?
Then ask why the down stream H2O separators do NOT work, well enough? As they have
instructions to empty it when ever or often...as if there is a membrane in the
upstream filter, why does H2O show up in the down stream separator?
Why not put another membrane filter down stream or in-between the separator and
the pump?
Then this leads to another question...emulsified H2O might not be
seen to the membranes as H2O and separators, or am I all wet with that?
components
the pump?
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
