NewsW
Mar 16, 2012Explorer
Cavitation simulations...
Nozzle Flow and Cavitation Modeling with Coupled 1D-3D AVL Software Tools
Number: 2011-24-0006
Published: 2011-09-11
Publisher: SAE International
Language: English
DOI: 10.4271/2011-24-0006
Author(s): Valdas Caika - AVL LIST GmbH; Peter Sampl - AVL LIST GmbH
Citation:
Caika, V. and Sampl, P., "Nozzle Flow and Cavitation Modeling with Coupled 1D-3D AVL Software Tools," SAE Technical Paper 2011-24-0006, 2011, doi:10.4271/2011-24-0006.
Citation
Abstract:
The paper is devoted to the coupled 1D-3D modeling technology of injector flow and cavitation in diesel injections systems. The technology is based on the 1D simulation of the injector with the AVL software BOOST-HYDSIM and 3D modeling of the nozzle flow with AVL FIRE. The nozzle mesh with spray holes and certain part of the nozzle chamber is created with the FIRE preprocessor. The border between the 1D and 3D simulation regions can be chosen inside the nozzle chamber at any position along the needle shaft. Actual coupling version of both software tools considers only one-dimensional (longitudinal) needle motion. Forthcoming version already includes the two-dimensional motion of the needle. Furthermore, special models for the needle tip contact with the nozzle seat and needle guide contact with the nozzle wall are developed in HYDSIM. The co-simulation technology is applied for different common rail injectors in several projects. It proved to be an efficient and user-friendly engineering tool. An example of piezoelectric common rail injector with a minisac nozzle is presented. Based on it, different numerical and technical aspects of the nozzle flow and cavitation modeling are discussed.
References:
Alajbegovic, A., Greif, D., Basara, B. and Iben, U., Cavitation Calculation with the Two-fluid Model, 3rd European-Japanese Two-phase Flow Group Meeting, Certosa di Pontignano, Italy, September 2003.
Arcoumanis, C., Flora, H., Gavaises, M., and Badami, M., “Cavitation in Real-Size Multi-Hole Diesel Injector Nozzles,” SAE Trans. J. of Engines, 109,2000, doi:10.4271/2000-01-1249.
AVL BOOST HYDSIM, User's Guide, Graz 2010.
AVL FIRE, Eulerian Multiphase, Graz 2010.
Boecking, F. et al., Passenger Car Common Rail Systems for Future Emissions Standards, MTZ 7-8/2005, Vol. 66, 552-557.
Chen, Y. and Heister, S.D., Modeling Cavitating Flows in Diesel injectors. Atomization and Sprays, 1996, Volume 6, 709-726.
?aika, V., Kammerdiener, T., and Dörr, N., “Operation of Piezoelectric Common Rail Injector with Diesel and FT-Kerosene,” SAE Technical Paper 2007-24-0070, 2007, doi:10.4271/2007-24-0070.
?aika, V., Sampl, P., Tatschl, R., Krammer, J. et al., “Coupled 1D-3D Simulation of Common Rail Injector Flow Using AVL HYDSIM and FIRE,” SAE Technical Paper 2009-24-0029, 2009, doi:10.4271/2009-24-0029.
Drew, D.A. and Passman, S.L. Theory of Multi-component Fluids, Springer, New York, 1998.
Ishii, M. Thermo Fluid Dynamic Theory of Two-Phase Flow, Eyrolles, Paris, 1975.
Giannadakis, E., Gavaises, M. and Arcoumanis, C., Modeling of Cavitation in Diesel injector Nozzles, J. Fluid Mechanics, 2008, 616, 153-193.
Payri, F., Margot, X., Patouna, S., Ravet, F. et al., “A CFD Study of the Effect of the Needle Movement on the Cavitation Pattern of Diesel Injectors,” SAE Technical Paper 2009-24-0025, 2009, doi:10.4271/2009-24-0025.
Sun, X., Kim, S., Ishii, M. and Beus, S. Modeling of Bubble Coalescence and Disintegration in Confined Upward Two-phase Flow, Nuclear Engineering and Design, 230, 3-26, 2004.
Wang, D.M. and Greif, D., Progress in Modeling Injector Cavitating Flows with a Multi-fluid Method. FEDSM2006-98501, ASME Forum on Cavitation and Multiphase Flow, Miami, FL, USA, July 2006.
Wang, D.M. et al., Interfacial Area and Number Density Transport Equations For Modeling Multiphase Flows with Cavitation, Proc. ASME 9th Int. Symposium on Gas-Liquid Two-Phase Flow, FEDSM'05, Houston, Texas, USA, June 2005.
Schmidt, D.P. and Corradini, M.L., The Internal Flow of Diesel Fuel injector Nozzles. Int. J. Engine Research, 2001, 2, 1-22.
Sou, A., Kinugasa, T., Numerical Simulation of Developing Cavitating Flow in a Nozzle of Pressure Atomizer, THIESEL 2010 Conference on Thermo- and Fluid Dynamic Processes in Diesel Engines, Valencia, Spain, September 2010.
Yuan, W. and Schnerr, G.H., Cavitation in Injection Nozzles: Effect of Injection Pressure Fluctuations, Proc. 4th Int. Symposium on Cavitation, Pasadena, CA, USA, 2001.
Language: English
Citation:
Citation
Abstract:
References:
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
