NewsW
Mar 19, 2012Explorer
Could weakened springs in the injectors have a role to play?
http://forums.hexus.net/automotive/66377-all-common-rail-diesels-inherently-flawed.html
or other oddball causes?
http://www.uniteddiesel.co.uk/
With the introduction of high pressure diesel common rail injectors a few years ago, we are now experiencing new diesel engine problems due to the failure of the diesel injectors. It has been found that a significant percentage of failures are caused by excessive return flow from the diesel common rail injectors. This back leakage problem within the diesel common rail injectors is causing diesel engine hard starting, erratic idling and lack of power. We now offer a diesel injector diagnostic kit that will enable you to perform a simple test to determine your common rail diesel injector leakage condition.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
