BenK
Mar 26, 2012Explorer
The Mad Norsky wrote:BenK wrote:
Anyone have a cross section of the CP3 pump?
Am looking to see if it too has a 'metering valve' on the intake side of the
cylinder head
Ask and you get:
Component list, as per the article this photo comes from:
1. Flange
2. Shaft
3. Polygonal ring
4. Housing
5. Gear pump
6. Overflow valve
7. Low-pressure inlet
8. Metering unit
9. Backflow connector
10. High-pressure connector
11. Plunger
12. Bucket
13. Suction valve
14. High-pressure valve (out to rail)
Thanks again and some more on an old thought
This shows (if to scale) the very or too small cavity for lubing
the cam/followers.
Add that if the 'inlet' to the cavity and the 'outlet' to the cylinder
intake too close to have the rest of the cam/follower cavity stagnant
with 'poor' lube property diesel and you have a very, very poorly lubed
cam/follower which has very high PSI conditions
Then add the other two variables that seems to coincide with failures
#1 H2O and #2 Heat
Both reduce lubricity
Both then creates a better environment for cavitation.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
