BenK
Mar 26, 2012Explorer
Not that hard to redesign a larger body, but the issue will be the committed form factor
It may not retro-fit
If stuck with the form factor, I'd add a pressurized lube system along with the
new ports to the cavity.
Pressurized and high GPH to both cool and lube, which would exacerbate the
piston not coming down during a metering system pinch off
Maybe high GPH, with low PSI, so large bores.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
