NewsW
Apr 12, 2012Explorer
W4RLR wrote:
You cite the very reasons why, with the exception of a coolant filter, my truck with a 6.0 liter engine is bone stock.
The blue spring (factory mod kit) to raise fuel pressure is proven.
Another proven trick is to not turn off the engine right away after a long hard pull on a hot day, but to wait 1 or 2 minutes for the turbo and so on to cool down a bit.
Turbo drain back tube (improved via factory) is another good thing.
STC fitting mod (factory) is a good thing if you need it or your fitting shows signs of failure.
Update the flash is good.
If you haven't had the EGR valve cleaned since 2009, do so.
Never let biodiesel near it.
Have fun.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
