NinerBikes
Apr 22, 2012Explorer
NewsW wrote:
Niner:
Can you do some sleuthing on the belt drive?
http://www.roymech.co.uk/Useful_Tables/Drive/Timing_belts.html
Use the table in the above link, do some measurements and you should be able to get a rough idea of how much energy / hp is being expended to drive the pump as per the chart: "Initial selection of Timing Belt ".
The pump using a timing belt is a good indication that it takes quite a bit of ommph to move fuel.
That will feed into a guess as to how much energy / heat is being dissipated into the fuel / engine area just from pumping the fuel.
14mm pitch, 30mm wide, and I know the pulley has a 3:2 drive ratio, overhead cam driven at 1/2 crank speed, HPFP at 2/3 crank speed. Redline at 5500 rpm. On my 2.0L the pulley speed is 1:1 5500rpm, same measurements on the belt. 30mm wide 14mm pitch. belt good for 130k miles. if you average 35 mph about 3700 hours life, might be higher than that to account for idle time in city traffic.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
