NinerBikes
Apr 24, 2012Explorer
Perrysburg Dodgeboy wrote:NewsW wrote:NinerBikes wrote:
It may also explain, thermal load, why Bosch went with an all aluminum design, including for the bore, instead of cast iron like on a CP3.
If I were to guess, the reason for aluminum is mostly to do with cost.
It is much cheaper to cast aluminum, though the thermal properties is an added bonus.
Their key bragging rights is the pump is both cheaper and higher pressure.
I don't think they have any bragging rights when it comes to this pump. If you can run it using the currant grade of fuel in the USA then it is useless, right?
We know they deleted an intermediate stage (gear pump). That is a very big chunk of the cost factor right there.
It did occur to me that with heat... deformation of the casting is a distinct possibility.
If you ever see a stronger / reinforced casting in later versions, that is your clue.
We have a saying in Mountain biking parts and racing:
Strong, cheap, light. Pick any two.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
