NewsW
Jul 30, 2012Explorer
NinerBikes wrote:
Why piezo injectors go BOOM and grenade your whole fuel system?
This explains a lot of things, also explains why 2012 and 2013 Passat TDI's with SOLENOID INJECTORS are not destroying HPFP's, while piezo injectors, even in 1600 bar VW V6 3.0L TDI's with piezo still are wrecking HPFP's.
The mechanic I spoke with recently said that they've done at least 4 HPFP's on 2009-2010 Touareg TDI's. I've no idea when Vw will switch the Touareg over to solenoid injectors, if they haven't already or if it's a 2013 development.
I need to see how fuel can get into the cavity that contain the piezo electric discs, and how it can get back to the fuel tank or pump.
Can you post a set of pictures or engineering drawings?
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
