NewsW wrote:
Those of you out there with the CP 4 Pump... here is the latest twist:
http://forums.tdiclub.com/showpost.php?p=3907598&postcount=3840
Quote:
Originally Posted by storx View Post
I just recently installed a fuel pressure gauge in my car because I been wiring up my gauges for big turbo install... I noticed that under full boost at higher RPMs the gauge shows my inlet pressure to Bosch pump was dropping almost in half... I talked to dealership and according to there repair manual it's still within tolerance so I'm ordering a air dog unit pretty soon here...I have a 24valve cummins that suffered from IP failures from low fuel pressure so I'm not taking chances and just adding additional pump to assure solid pressure
Hmmmm... cavitation, if it occurred, could theoretically provoke a failure of the pump's HP section.
This is an interesting possibility....
Cavitation would mean many things, including lack of lubrication.
#1, lost lub at that spot
#2, molecules removed to create pitting. Over time flakes of varying sizes
#3, those molecules of material is now in suspension to then be pushed
into the down stream system
Note the removal of the coating from one part and not the other.
That can mean the DLC coated parts have different surface tension characteristics with diesel fuel.... or contaminants like water... or...
Such a key indication of the lack of understanding of both what they
are dealing with (root cause) and of the material(s)
I know that diamond is not easily 'wetted' (that best non-stick material
known to mankind thing). If it needs lube, that needs to have some
pretty high film strength rating.
Does this then say two like surfaces of not easily wetted material
was NOT getting enough lube?
That then points to one of my original premises that both diesel is
a poor lube and that the cam cavity is so poorly designed to have
stagnant areas NOT lubed and/or not flushed with new lube.
Yes, what does H2O do to all materials inside that poorly designed
cam cavity?
Summer is nearly over... and I am now sitting around waiting for the failure reports to come in for the next iteration of the analysis.
New thought based on this...wonder if the hot summer, summer fuel conditons,
and the condensation cycles of summer show up later in the summer?
An accumulated process(s)
H2O has microscopic bubbles of air. Does diesel? Those are the spots
more easily or where cavitation occurs
This system has so many 'return' lines or spots...wonder if the filtration
system is able to handle all of the particles generated by cavitation
going back to the main tank.
Bet some of the particles are smaller than the filter filtration spec
At 2000 BAR, bet diesel is getting into associated parts/cavities/etc
that is unthought of during their design process(s)
