NinerBikes
Sep 26, 2012Explorer
NewsW wrote:ricatic wrote:
Dodge/Cummins does not use the Bosch CP4.x series pump...yet...and I doubt they will given all the issues they have seen with their competitors that use the CP4...
Regards
Designs for the 2014 model year (the next opportunity for change) was frozen this past year.
To simultaneously achieve the EPA 2014 emission targets without the higher pressure would require a much larger tailpipe treatment system.
Maybe we should start a pool on what they do.
The alternative is an entirely different manufacturer for the fuel system, which has its own risks.
Delhpi has a market! Square shoe follower. I'd run these as clean as you can before tailpipe treatment before the redneck boys start ripping off the whole DEF /DPF exhaust systems.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
