NewsW
Oct 24, 2012Explorer
Additional Info:
There are 3 heater circuits, in tank heater, pump heater, and the heated line.
The one that is at fault is the in tank heater.
AFAICS, NOTHING to do with the DEF douser (termed "injector" by the tech).
Diagnostics include:
A) Check wiring for fault -- damage
B) Swap in a new tank sensor (or tank module).
Here is the diagnostics:
:C
Did the tech that did the work finish high school?
Reductant Heater Performance Check Operation (Heater Circuit #1):
DTCs P209F – Reductant Tank Heater Control Performance
Monitor execution Once per heat cycle (after cold start)
Monitor Sequence P20B9, P20BB, P20BC must complete for P209F
Sensors/Actuators OK
tank temperature sensor, tank heater
Monitoring Duration 2200 ms for fault detection
Typical Reductant Heater Performance Check Malfunction Thresholds
P209F: temperature increase < 0.5°C
:C
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
