NinerBikes
Nov 01, 2012Explorer
NewsW wrote:NinerBikes wrote:
Toyota /Nippondenso's approach to HPFP pump design.
The Nippon Denso approach can do much less volume, harder to add capacity vs. the CP4 (which can just add cylinders.
http://www.globaldensoproducts.com/em/dem/crs/supply_pump.html
Much more expensive to manufacture.
Good only to 1,800 bar (a lot less for the higher volume models).
But it is much easier to design hydrodynamically.
Would like to see what coatings it has.
How is it lubricated? Is it fuel in the whole thing, or is it lubricating oil on the outside loop? The photo suggest it is fuel lubricated.
Note it is paired with solenoid injectors that are probably much slower than the piezo electrics:
http://www.globaldensoproducts.com/em/dem/crs/solenoid_injector.html
NewsK, make note of the icon that shows Earth with a link of chain, click on it, and fill in the field with copy and paste to get your links to work.
NipponDenso Solenoid Injectors.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
