NewsW
Nov 24, 2012Explorer
Failure... VWs... reported here:
VW HPFP Pump Failures
Interesting, assuming some non-report bias, the rate is still in the range of .1% to 4%.
Calculation here:
Range
Now that leads us to a discussion of what is an acceptable failure rate?
Annual failure rates (all units in operation)
Below 10% sure
Below 5% sure
Given how catastrophic it is, I'd say, well below .1% for every year of operation, arithmetically added.
That still means in 10 years of ownership, every unit have a 1% change of failure.
Note that if a failure were to occur, the "savings" from operating a diesel is wiped out.
Given the unknown contribution of contaminated diesel and biofuels to the problem, I'd say buying a late model, CP4 HPFP / EPA 2010 diesel is now risky business unless it is given away for free.
The elephant in the room:
What is the failure rate of equivalent Heavy Duty / Medium Duty EPA 2010 diesel HPFP pumps?
Is this peculiar to the Bosch system or is everyone having problems with high pressure diesel injection?
Calculation here:
Range
Below 10% sure
Below 5% sure
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
