durallymax
Mar 07, 2012Explorer
hoopers wrote:NewsW wrote:
Now we find out about filtration:
Filtration Technology Challenges for Common-Rail Diesel Engine Fuel Systems
Number: 2009-01-0874
Published: 2009-04-20
Publisher: SAE International
Language: English
DOI: 10.4271/2009-01-0874
Author(s): Christopher J. Salvador - Caterpillar Inc.
Citation:
Salvador, C., "Filtration Technology Challenges for Common-Rail Diesel Engine Fuel Systems," SAE Technical Paper 2009-01-0874, 2009, doi:10.4271/2009-01-0874.
Citation
Abstract:
The focus of this study was to determine the role of liquid filtration in controlling debris in fuel and maintaining common-rail fuel system life for off-highway diesel engine applications. Three key areas of filtration design surfaced as most important areas of focus – basic filtration efficiency, robustness of filter manufacturing, and filter assembly cleanliness from production (before and during installation into fuel system). The study also revealed the importance of designing fuel filtration systems consisting of primary filtration (suction-side water separation and particulate filtration) combined with pressure-side particulate filtration. The performance characteristics of the filtration system as a whole were found to be extremely critical in optimum fuel system performance and life goals, especially in severe-duty applications.
The study analyzed two filter systems – the Control System that consisted of pre-common-rail technology and the Proposed System that included all of the improvements designed to adequately protect the fuel system. The Control System consisted of B 20(c) = 75 primary filtration and B 8(c) = 75 secondary filtration. The results of the study recommended the Proposed System consist of B 10(c) = 75 primary filtration and B 4(c) = 200 secondary filtration. This system improved fuel system life by 20× in normal applications and nearly 10× in heavy-duty applications.
Several test methods were used to generate data including the multipass test (ISO 4548-12), fabrication integrity ( ISO 2942 ) test, and specially developed production cleanliness and fuel system simulation tests. The study examined the adequacy of existing filtration technology in protecting common-rail fuel systems (benchmarking) and determined acceptable design requirements in the previously mentioned areas for individual fuel filters (pressure-side filtration) and filter systems (combining suction-side and pressure-side filtration).
From what I have read, GM filters down to a smaller particle level than Ford (no idea about VW filtration). I don't completely understand where the filter is located, but I would guess it is before the pump, thus filtration should play an important role in pump protection...this seems obvious to me.
Is lubricity the culprit? How does filtered particle size affect lubricity?
I have seen no statements or data proving lubricity is the culprit. Just supposition and assumptions, really. I am not saying its not lubricity, just that it could be something else, and lubricity is a red herring at this point. The fact Canadian fuel meets the ASTM specs, and yet there are failures? This is a glaring exception that makes me question the lubricity spec and how it might play into the pump failures.
This makes me think ASTM lubricity might play a minor role, and there is a larger factor out there. But that is just my thoughts....
As to people claiming the failure rates are similar between GM and Ford (and what about VW?), I would question how accurate this data really is? Is EVERY pump failure included in the sample lots? What is the nature of the pump failures included in these samples...are they the same?
I did call a couple duramax dealers today regarding adding diesel additives on my 2011 duramax. One dealer seemed to understand my concern and said GM does not support ANY additives. Though he did say customers are adding it, but again, the official position is NO additive. My 2011 owners manual makes no mention of any supported additive, except to consult your local dealer.
The other dealer seemed to be confused on the subject and really didn't have any advice except one doesn't really need additives.
However, the GM first dealer said my 100000 mile warranty would cover any fuel pump issues, so for me, I might just go with standard fuel, and if I am one of the unlucky ones, I will just count on GM fixing my fuel pump. I doubt I will keep my truck past 100000 miles.
still on the passenger side valvecover, before pump. It would take a hell of a filter to hold up to that much PSI.
About Around The Campfire
37 PostsLatest Activity: Feb 22, 2025
