Surgtech94 wrote:
ken56 wrote:
Most RV parks set aside at least some sites for overnighters. The only reservations I make are at our destination otherwise we use the RVPARKY app to find parks on our route. It also shows gas stations and Cracker Barrels and other places. It gives you all the info you need to find an overnight park. We start looking at around 2 or 3 pm to find a place to stay. We call them and then have them hold a site with an estimated time of arrival. I have the luxury of owning my own time because I am retired so I can take as much time as I want to going somewhere.
You will find it very difficult to hold to a schedule if you try to make reservations at every park you think you might stay at...and sometimes you might lose your reservation deposit if they require one and if you don't make it.
Get better acquainted with how your RV systems work. Water pumps, slides, lights  and furnaces work off of your 12 volt battery. Depending on if you have to run your furnace while you are not on shore power you will deplete that battery in one night depending on how cool it is out and frequency of running it. At some time you will have to settle for staying in a Walmart parking lot so understand how to conserve your battery. Like others have suggested, upgrade your battery to a better deep cycle marine battery with a high amp hour rating. Your air conditioner requires 110 volts to run so if it's hot out and you can't plug into a shore power source you will not have that available to use.
Thank you.  I guess I missed the battery upgrade.  We just need to get out of our comfort zones of staying in state parks
A better idea for you to learn how to use your trailer is to go to the place you have been going to. The difference is when you get there, pretend the water and electric are not there. Use your fresh water tank, and propane. If things go bad for you, plug in or hook up. That way your time isn't wasted and you can learn what to do next time. Actually, you can do the same thing in your driveway just to learn how to use your rv in ways you haven't before.
It may sound strange to some here, but when I pull in to a full hookup rv site, I am lost. We have only done that two or three times, and it just feels like cheating to me. 8)
