- HorsedocExplorer IIThe heights on the tunnels are marked and measured for the sides. Much higher out toward the center. even at 13 feet, which is darn high!!, you will be fine. Just crowd the center line and pay attention
- joloooteExplorer13' RV ? Must be an OutLaw Toy hauler.
- WrongWayRandallExplorerHere's some info on the tunnel heights on that route
http://www.aitaonline.com/Info/Low%20Clearances.html#Tennessee%20Low%20Clearances
- R - WrongWayRandallExplorerThey are doing construction work on that road just inside the park, so you may want to check the NPS website for the times when it's going to be down to one lane.
http://www.nps.gov/grsm/planyourvisit/temproadclose.htm - jaycocamprsExplorerBut what is the height of that tunnel?
- HandbasketExplorerThis may get your attention...
It's on the uphill side going toward Cherokee, so not a real problem.
Jim, "Mo' coffee!" - magnusfideExplorer IIIYou should be okay. Lot of elevation changes and deep curves so be rested when you do it.
About Bucket List Trips
13,488 PostsLatest Activity: Nov 02, 2018
