Robt65's avatar
Robt65
Anzalduas Bridge Crossing with A 40 ft DP
Anzalduas Bridge Crossing with A 40 ft Monaco Dynasty DP and 20 foot toad trailer loaded with a Chevrolet 2500 HD Crew Cab.
I finally graduated from my previous 39 ft TT and will now pick up my DP in the middle of January. The TT taught me a lot of lessons, some a bit painful! (smiling) None the less I am moving forward and I am sure that I'm about to enter a whole new level of education which I might add is a bit intimidating. I have always used the Anzalduas Bridge crossing and have never had any problems headed south via 40 East and west and then onto 57 south. I am a bit unsure about the process one goes through with a motor coach and a toad so a few questions are in order.
I have never taken my TT through Anzalduas as I used other crossings then returned to McAllen where I stayed at an RV park for the duration, with several stateside trips in between learning more and more about RV'ing..
Can a single person bring both an motor coach and a toad across on the TIP's or is only one TP allowed for a driver? What is the cost of a ten year TIP for the Monaco? My wife does not drive the larger crew cab and she certainly will not drive the Coach.
Second, roughly how long does it take to cross into Mexico with all the X Ray etc that one apparently has to go through at the POE at the Anzalduas crossing.
I see that one seems to pull off to the right for the RV inspection and then a whole lot of bells and whistles seem to go off. What's up with that?
Are the Cuota's using the number of axles (this Monaco has a tag axel)or are they counting wheels on the ground to figure your cost for using the particular portion of the numerous Cuota's involved heading south to Querétaro?
Does anyone know for sure if Pemex diesel now has low sulpher in their tanks or not? I understand in Baja they apparently do have.
Thanks in advance for any information regarding my questions are answered.
robt65
