Tequila's avatar
Tequila
Dealing with bad power
One solution is a voltage regulator. These are available in Mexico from ISBMex.
There are distributors in various parts of Mexico. This generally eliminates the need for a Voltage Protector, which costs about the same, although having both is a good idea. This unit is reliable & robust and it certainly gave me far more consistent power. The 4 KVA version is sufficient.
The problem is, you have to wire them up yourselves and you need to bring a couple of items down from the US. We are sourcing these for our Caravans and I have produced an instruction sheet on what you need to bring and how to wire them up. You may download it at
Regulator Hookup
  • Hi Tequila,
    Nice article! Tripp-lite makes a power conditioner that can handle 2400 watts. Just about perfect for protecting an air conditioner. They say it maintains 120 volts and does buck and boost.
    I have a sola basic unit.
    I've been told there is a adjustment to allow the voltage set points for boost to be adjusted. Do you happen to know which "pot" it is on the circuit board?
    Regulator Hookup
  • We absolutely swore by ours when we were in the RV. We even found a number of places in the US where it was necessary, high end parks in San Diego specifically.
    Fortunately we have great electric to our house. We were prepared to buy the BIG one and wire in the entire place.
    If you travel in Mexico, they are a must have, and will pay for themselves in no time at all.
