Ed_White's avatar
Ed_White
Diesel Fuel In Mexico - Update re Late Model Diesels
For almost 8 years I have been gathering data on, and reporting to this forum annually on, the behavior of diesel powered motorhomes, vans, and pickup trucks while in Mexico, where most of the diesel fuel is still LSD (Low Sulfur Diesel), up to 500 ppm. Unfortunately, ULSD (Ultr-Low-Sulfur-Diesel), 15 ppm, is available only in border cities/towns, the Northern Baja, Mexico City, and Monterrey.
In particular, my present database (November 2015) contains detailed information about the effects of Mexican LSD on the emissions systems of Ford Powerstrokes, Dodge RAMs, and GM Duramax systems for model years 2007.5 through 2015. Owners will be pleased to learn that none of these vehicles for model years 2007.5 through and including 2012 have any significant issues while using Mexican diesel. There may be occasional blue smoke during regeneration cycles, as sulfur compounds in the emissions system are burned off, and 2011/12 Duramax powered pickups may display “BAD DEF” and speed limitation warnings from time to time, but there has never been a confirmed situation of any of these vehicles becoming disabled or going in to “limp mode” due to sulfur in Mexican fuel. A regeneration cycle ALWAYS occurs and burns off the sulfur compounds before a serious speed limitation problem develops.
For 2013 through 2016 Duramax powered vehicles, management of the situation is required because these pickups can go in to limp mode unless regenerations are forced when “BAD DEF” messages appear. There are, however, 6 volunteers stationed across Mexico, including me, who can quickly provide information on how to force those regenerations and return the vehicles to normal operation. It is better to be prepared in advance though, so owners of 2013 and later Duramax pickup trucks should contact me at whitetmp@aol.com BEFORE entering Mexico.
Based on the data provided to me by owners, there are no recorded significant issues for 2013 and later Dodge RAM diesels while on Mexican fuel, although the engine light may come on and stay on for extended periods of time. Otherwise the vehicle operates normally, and the engine light extinguishes once the truck is back in the USA and has gone through a couple of tankfuls of ULSD.
Similarly, 2013 and 2014 Ford Powerstroke diesels have no reported issues, other than an occasional temporary engine light on. With respect to the 2015 Ford Powerstroke though, there COULD be a major issue for owners. The following story explains why:
In January of 2015 the owner of a 2015 Ford F350 Powerstroke joined a caravan tour into the Baja. As expected, his truck exhibited NO symptoms of temporary sulfur poisoning of the emissions system while he was towing his fifth wheel trailer. This is because towing a heavy trailer, or carrying a camper in the truck bed, provides sufficient load to keep exhaust gas temperatures elevated high enough to prevent the deposit of sulfur compounds in the emissions system. (This is also true for late model Dodge and GM diesel powered pickups).
In this specific case though, the owner left the caravan while in the Los Cabos area and traveled to La Paz, where he booked in to an RV park, unhooked his trailer, and began driving the truck with no tow load. Within a week or so, his truck went in to speed limitation, and eventually limp mode. He contacted the local Ford dealer in La Paz and discovered that there is NO ability to service late model Ford Powerstrokes in Mexico. He then contacted a dealership in the U.S., which canceled his warranty when it was discovered that he was in Mexico.
At that stage he researched the problem on line and contacted me, but it was too late to assist due to the truck being in limp mode. The only way to clear the sulfur compounds from the emissions system, and return the truck to normal operation, would be to run a Service Regeneration.
This owner then made the decision to import a delete kit in to Mexico, and within two weeks he had removed the entire factory emissions system and installed the delete kit, at which point he was able to get the truck running normally again.
The HUGE problem with this case, is that there is no way to know whether this single owner's experience is indicative of a larger 2015 Ford Powerstroke issue that will affect other owners driving on Mexican diesel, or whether his truck suffered a completely unrelated emissions system component failure that put his truck in to limp mode.
Erring on the side of caution I thought it would be wise to make a recommendation based on my extensive experience with similar problems on GM duramax post-2012 models. In conjunction with a different 2015 Ford Powerstroke owner, I have confirmed that the latest model Edge Tuner CT2, can force a regeneration on the 2015 Powerstroke. I am therefore recommending that any 2015 Powerstroke owner planning to drive into Mexicoand use Mexican diesel should purchase and carry an Edge CT2 Tuner - during the purchase, owners should confirm that the CT2 they are buying can initiate a regeneration cycle. (Please note that I do not work for Edge and I receive no compensation for this recommendation).
Once in Mexico, if or when the engine light or other DEF or emissions related message shows, a regeneration should be initiated, especially if there is warning of speed limitation. Following the regeneration, NOX emissions can be expected to return to normal range for long enough to cancel the emissions fault codes. If the Powerstroke behaves under these conditions the same as the GM Duramax post-2013, the engine light could remain on for up to 30 miles and/or three engine warm-ups, but will extinguish by itself.
Please note that I have insufficient information at this time to accurately describe the process because it is presently at the stage of a “Beta Test”. I would have preferred to witness the process myself on a 2015 Powerstroke in Mexico but that hasn't been possible to do so. For this reason, it would be of great assistance to me, and to owners of late model Powerstrokes, if owners could share their Mexico experiences this season with 2015 or later vehicles. There is every reason to believe, based on extensive observation of 2013 and later Duramax powered trucks, that the Edge CT2 will, via its regeneration function, prevent any major sulfur-in-fuel problem from developing, but I need further confirmation before becoming 100% confident.
Feel free to contact me if you have additional information, either via a private message, or directly to whitetmp@aol.com
  • Ed,
    It's always to informative to read your posts regarding fuel in Mexico.
    Personally, I have a 2015 Ford diesel and was seriously contemplating a trip to Baja this winter.
    That trip will probably be curtailed to one tank until I hear further news.
    Please keep up your best efforts.
  • briansue wrote:
    A warranty can easily be voided if the operator does not comply with the terms spelled out in the warranty. Proper oil changes - filter changes - etc. If the warranty spells out improper fuel then that could be a sticking point. I have no idea. I have no knowledge. I would have to see the fine print in the warranty and know exactly what the wording means. I once had a car that spelled out if you put rust-proofing or undercoating on the car and the car rusted you voided the warranty - spelled out clearly - but the dealers still put the stuff on the cars. Facts are facts and without facts we know nothing. Speculation is not fact. No one but the vehicle manufacturer can provide those facts.
    The whole thing comes down to proof. I personally have done at least a million USD worth of warranty work. From Diagnostics to installing the new parts to submitting the claim to the factory. For each job.
    If you submit a part as faulty, the factory will test that part. If it is faulty you get paid. Otherwise the claim is rejected. If your warranty claim is written incorrectly, even if the part is faulty, the claim is denied. One mistake in writing the claim, resubmitting the paperwork could cause a 90 to 120 day delay in reimbursement. And you can't go back to the client and ask for money, you deemed it warrenty and they are not required to pay. I could give a class.
    When a part, engine, whatever fails you can be expected to have some questions asked. The tech. may know you are not being totally upfront and honest, because that is his job, to know the equipment, engine, emissions parts. But it is not Judge Judy and he will accept your story as true. Even if he knows you are probably lying. He's getting paid regardless but doing what is expected by asking the questions.
  • A warranty can easily be voided if the operator does not comply with the terms spelled out in the warranty. Proper oil changes - filter changes - etc. If the warranty spells out improper fuel then that could be a sticking point. I have no idea. I have no knowledge. I would have to see the fine print in the warranty and know exactly what the wording means. I once had a car that spelled out if you put rust-proofing or undercoating on the car and the car rusted you voided the warranty - spelled out clearly - but the dealers still put the stuff on the cars. Facts are facts and without facts we know nothing. Speculation is not fact. No one but the vehicle manufacturer can provide those facts.
  • tepetapan: They cannot void your whole warranty but the mfrs. can and do void engine warranties when owners modify emission systems or ECM's.
    Moisheh
  • Thank you for sharing this info Ed. Believe me when I say it is appreciated by a lot of people including myself.
    Thanks and have a great day.
  • No one can void a warranty by looking at the computer memory. It just can not be done. Offering the idea it may have happened in Mexico is sort of like shooting yourself in the foot. It is just that easy.
    Act like your local politician and deny, deny, deny. The burden of proof is on the dealership. Sometimes you just need to stop talking.
  • First off - I know nothing nor do I claim to know anything. I do not know who is who or what is what. This topic of diesel fuel in Mexico and whether you should or should not operate your specific vehicle with the available fuel in Mexico comes up each year. And each year I try to say the same thing. Who knows what is OK to do with your vehicle? I would think it would be the manufacturer and that would be who I would ask and whose advice I would take. I would call the engineering department of the company that built my engine and ask them about it - not a dealer - not a mechanic - not a magazine article - and what can anyone say about info on the internet?? Verify!
    We own a 2006 Class A with a 400 Cummins so we have no stake in this discussion. The annual report in this topic has to do with pickups with little diesel engines. No mention of the larger engines as far as I can tell.
    So what happens if you modify an engine that is still under warranty - what happens to the warranty?
    I offer no advice other than to seek advice from known sources such as the engineers where the engine was built - who would know better?
    I have no idea who the author of these annual reports is or what his credentials are or where he gets his info. I don't really care. Unless he is an engineer with the company that built the engine I personally would not pay much attention. How would you know?
    So he mentions a product and I did a search to find out what exactly that product might be and what it does and much it costs and where to get it. Here is what I found - can't find a CT2 but here is what it could be..........
    https://edgeproducts.com/products
    DIESEL EVOLUTION CTS2
    THE NEXT LEAP IN EVOLUTION
    Innovation and quality are part of Edge’s DNA. The Evolution CTS2 has no peer in the marketplace and is designed for “WOW”! As an in-cabin controller and programmer, the Evolution CTS2 is the ultimate package!
    The Evolution CTS2 reprograms your vehicle's stock computer. It resides in the cab with one simple cable connection to the OBDII (diagnostic) port. The Evolution is used to save the stock files from the vehicle's computer and then upload the Edge calibrations into the vehicle's computer. This amazing product is available for both gas and diesel pickups and SUVs. This product comes with multiple power levels custom tuned by a whole team of engineers, and can be installed in minutes without ever popping the hood. The Evolution CTS2 greatly increases horsepower and torque. Not only does it re-tune your vehicle, it stays mounted in the cab and features real-time, monitoring of vital engine data.
    Evolution CTS2 Features:
    • Slim, sleek case design
    • 5” full–color, high-resolution, swipe screen
    • Custom color mixer for gauge arcs, needles, and backgrounds
    • Multiple gauge screen layouts
    • Fully customizable backgrounds
    • HDMI style plug for power and linking EAS accessories
    • One-touch easy menu navigation
    • Notification center
    • Performance tuning for mileage, towing, daily driving, and performance
    • Up to an additional 180HP and 440 ft lb TQ* on Diesel applications
    • Up to an additional 50HP and 50 ft lb TQ* on Gas applications
    • Tuning for shift points, shift firmness, TQ management, fuel pressure and more*
    • Adjust speed and rev limiters*
    • Correct speedometer*
    • Switch between US or Metric units of measure
    • Light sensitivity meter to dim screen as ambient light decreases
    • Internet Updateable
    $679.00
  • BTW I saw DEF fluid for sale in an autozone in Mazatlan last week (the one on hwy 15)
    BTW our tailgunner on our spring caravan last year had a 2015 dmax, towing a 5th wheel. The trip was about 3000 miles in total and he had no issues and has reported none since. He did use it without being under load a few tiems, but not excessively.
  • ED: Good information. Ford cannot and does not cancel the warranty. What they do is note what happened in their computers and do not honour any warranty related to the use of LSD. So any driveability issues would not be covered. I would also bet that anything to do with the emissions system and the entire fuel system. Another RV'r once joked : The only thing left under warranty is your radio! This also affects the saleability of your vehicle. BTW: Check engine lights will leave a code in the ECM.
    Moisheh
