JT's avatar
JT
I-15 @Barstow, CA and I-215 connection to I-10
(24' class C, no toad)
Does anyone know of the *current* road conditions on I-15/I-215 from Barstow, CA, to where 215 runs into I-10? I know there's some construction on 215; how much impact does this have on traffic flow? Any other issues currently on this route? I know Cajon Pass; :)
(BTW, I've looked at the CA DOT site, but can't get the area traffic cams to load!)
Thanks for any information!
  • I just came through there on Tuesday (via 210) and didn't run into any didn't run into any significant construction.
    Keith
  • "...at that point I would get off the 215 just prior to San Bernardino and get on the 210 east. It will curve around San Berdo and hook up with the I-10 in Redlands."
    Thanks for that reminder. I usually take the 210 also, but because I'm leaving my overnight spot in the early a.m., I'm trying to avoid as much of the commute mess as possible. Not that this is easy with *any* route! :D
  • It sounds like you want to get on the I-10 east...correct? If that is the case, I-15 from Barstow over Cajon Pass is just fine. Taking the 215 off of the I-15 is also just fine. However, at that point I would get off the 215 just prior to San Bernardino and get on the 210 east. It will curve around San Berdo and hook up with the I-10 in Redlands.
    Getting off the 215 and on to the I-10 in Riverside is difficult with lots and lots of traffic.
    As far as construction on the 215.....haven't been that way in a long time as I always take the 210.
    Hope this helps
    Ron
