Bken72's avatar
Bken72
Lewiston to Lolo pass highway 12 road questions
Hi all, we are planning to travel on highway 12 through Idaho on our way from Oregon to Montana. We are in a 1 ton Silverado gas motor hauling a 33 ft crossroads travel trailer, which is pushing the boundaries of what the truck should be hauling. We are looking for info regarding concerns we should have on any of the downhill sections and whether anyone has had any major issues such smoking the brakes. Any input as to whether this is a stupid thing to attempt, or if anyone has made the trip and has suggestions etc. is much appreciated.
  • We've taken that route many times usually coming home from Yellowstone working our way back down through Oregon and back to So. Calif in our class A.
    95% after you pass Lewiston is meandering road about 45 mph. The only steeper section is going up the Lolo Pass as you enter Montana but it is not bad at all. It is a very pleasant drive and we think well worth it. Toward the Montana end at the start of the pass is a campground called Powell. It has electricity and is on the river. If you time it right and want to camp there you'd hit no traffic going up the pass the next morning.
  • Take a look a the Mountain Directory - West. It will give you information about steep grades and curves for your route.
  • Downshift BEFORE you start gaining SPEED
    Use brakes sparely
    STAB them and quickly scrub off speed (reduce by 10 mph) then GET OFF THE BRAKES
    Repeat as needed to maintain downhill speed
    Uphill.....grear down and use higher RPM
    Stay in right lane and don't expect ahny spped records
  • Know how to downshift. We went up that way and it's a fantastic scenic route. It follows the river for much of it and kayakers and bicyclists are all around. At least during normal times. We had no problems with the truck and while there are grades I don't recall any extreme climbs or drops. IIRC the road climbs steadily for the whole first section.
