mikefos's avatar
mikefos
Red River NM to Salida CO
Howdy,
We are leaving this weekend for a 3-week northeastern New Mexico and southern Colorado trip w/ a 35' TT and long-bed crew cab truck. Route chosen from Red River to Salida is: NM 522-> CO 159 to Ft. Garland ->CO 160 to Alamosa -> CO 17 to Salida (actually staying in Howard). How is this route? We've driven the other side of the mountains from Walsenburg to Cotopaxi. Is this western route similar? Thanks!
Mike
  • We just got back from Twin Lakes / Leadville, CO which is just to the North of Salida. If you go sightseeing up that way the Leadville Railroad allows dogs. It is a beautiful trip up 1,000' in to the mountains for $37.
  • jrp wrote:
    You'll be fine on that route. Most of your elevation change will be on the short initial section from Red River to Questa. After that you're out in a broad valley all the way until Poncha Pass just before the 285-50 junction. Its a small pass by Colorado standards. These roads are similar to 69 you used on the other side of the mountains, except the busy 160 section, and this side is not as scenic as 69.
    Thanks Jim. We'll be coming home (Fredericksburg, TX) on CO 69 to Raton Pass -> Lubbock TX -> FBG TX.
    Mike
  • You'll be fine on that route. Most of your elevation change will be on the short initial section from Red River to Questa. After that you're out in a broad valley all the way until Poncha Pass just before the 285-50 junction. Its a small pass by Colorado standards. These roads are similar to 69 you used on the other side of the mountains, except the busy 160 section, and this side is not as scenic as 69.
