prstlk's avatar
prstlk
toad brakes?
We have for several months been preparing for the dream rv Can/Alaska trip. We have poured over websites and think we have a good grip on what to expect.
The issue of towed vehicle brakes is some what vague.
We have a 2003 ford ranger on a blue ox tow bar, safety chains, lights, and a brake away system.
towed behind an 07 mh with a 10K hitch.
Are we OK. .if not what do we need to do, or were do we go to find out?
Thanks 4 all..jw
  • traveylin wrote:
    I do not use a toad braking system as I consider them to be excessive failure contributors. Your Ranger is a lite truck and if you check GVW for the combination you will likely see it within the towing capacity of your mh. My simple observation during last years 4 month Alaska trip was that about 1/3 toads had aux brakes, 2/3 did not. My observation of the dingy forum the last 5 years is that folks with aux brakes tend to justify them, folks without them smile and move on....
    Yup.
    It only takes once to feel them kick in to prevent you from hitting something to as you say 'justify them'.
    Not to mention in some states/insurance companies they are required.
  • I do not use a toad braking system as I consider them to be excessive failure contributors. Your Ranger is a lite truck and if you check GVW for the combination you will likely see it within the towing capacity of your mh. My simple observation during last years 4 month Alaska trip was that about 1/3 toads had aux brakes, 2/3 did not. My observation of the dingy forum the last 5 years is that folks with aux brakes tend to justify them, folks without them smile and move on.
    This was our second trip to Alaska and have only seen three moose well back off the highway in the trees. But those frost heaves will sneak up on you and really shake things up.
  • There are several braking systems on the market. I use the Patriot by Blue Ox.
  • We've made that trip twice towing our 2009 Ranger 4x4 and I would not attempt it without towed brakes! You are likely to see some 10% grades with numerous 1 mile plus 6-8% percent. Yes, you can make it without towed brakes if you start down the hills VERY slowly with your engine brake fully engaged in 1st or 2nd gear. But what are you going to do when a moose runs out in front of you and you need to make a quick stop or a huge frost heave suddenly appears and you are traveling faster than you should?
    Supplemental braking systems are expensive but you should keep I mind if you have an accident and the state or providence you are located requires brakes on your towed your insurance company may not pay your claim!
    Take a look at Ready Brake. We have been well satisfied with ours and they are reasonably priced.
    Hope you have as much fun as we have had on our trips up and down the Alaskan Highway!
