Tequila wrote:
All of Baja including the south is now ULSD according to Dan Goy of Baja Amigos.
I know lots of people running late model diesels down as far as Manzanillo & back every year that have not had issues.
Baja California Sur is all pure Mexican refined diesel according to Petroleos Mexicanos. I guess you'd have to draw a clear jar sample, of fuel like I did from a Baja Sur station and compare it to Antonio's gasolinera ULSD which is water clear in El Rosario. The Vizcaino diesel for instance is unquestionably more yellowish. Ask a chofer de pipa (that's a tank truck driver) dumping fuel in Guerrero Negro where he picked up his load "Pichilingue Señor. Pipas do not come south of El Rosario"
Yeah, I can really see a tanker making a 2,000 mile run from the tank farm in Ensenada... The next main entry point (pipeline) is through El Paso / Juarez and that line does NOT run to Cabo San Lucas.
People with a vested interest in not losing prospective customers due to the no ULSD issue may not have the best perspective of the point.
The only other storage point on the mainland is in Guaymas. I did notice a tank farm (small in Santa Rosalia. The joint venture refinery in Deer Park is taxed enough as is to produce ULSD for the Houston area (Shell) plus northern Mexico.
If regeneration does not reduce carbon, what is the point of regeneration? I am not a diesel expert.
The point I ponder is the one about someone loudly voicing an opinion that they have traveled extensively "all over Mexico" with a diesel supposedly sensitive to the ULSD requirement and bragging about it. Not the bragging -- if maybe he ended up faced with a bill for replacement of the particulate filter costing of thousands of dollars and did not have the gumption to make public the fact that he had made a costly mistake.
Time is the key. Operating the newer sensitive diesels on LSD. If nothing is heard in the next several years then I might be more convinced than I am now. The kicker is that diesel from regular refineries could be treated in the future to halve the amount of sulfur and a person would never know about it. I used to load tank trucks bound for Stauffer Chemical at a Shell Oil refinery. The molten sulfur was transported 40 miles then converted to sulfuric acid, returned to the refinery to make alkylate. This entire process needs to be adopted big time by Pemex and Mexico. The Houston refinery makes alkylate and some of it finds its way into Pemex Premium gasoline.
