westend
Apr 08, 2016Explorer
If you are just doing this to charge batteries in the towed-behind, a more elegant solution might be to use the 12V system of the coach to do it.
An alternative is solar.
Having a hot 120V wire between moving vehicles is a risky business. 20 amps at 120V is significant power, enough to start a fire or cause some damage. I wouldn't do it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
