PNW_Steve's avatar
PNW_Steve
110v Residential fridge install
Hey Everyone,
I finally made up my mind regarding the replacement of my failed 6cu. ft. RV fridge in my little 5er.
I decided to go with the Whirlpool model #WRT111SFAW 10.7 cu. ft. "apartment" fridge.
This unit is 24" wide and about 60" tall so some minor cabinet mods were required. That completed the fridge fits fairly nicely. I still have minor interference on one side from the waste tank vent pipe. I am still working on that bit.
I had hopes that it would be miserly on the power consumption so that I can keep it cool while on the road running a Xantrex 1000watt PSW inverter and 2 golf cart batteries. The Energy Guide info indicated a typical energy consumption of 381kWh annually. Slightly over 1kWh daily.
With the unit installed in the cabinet, moderately filled and ambient temps running 52-85F we are consuming .55-.60kWh daily as measured by my new Kill-A-Watt meter.
With my 215AH battery bank and my 94% efficient inverter I should be able to run 24hrs without discharging the batteries too deeply.
The usable space is wonderful and the power consumption well below my expectations. We'll see how it fares on our next trip.
I am still undecided on the solar question. I haven't been boondocking like I used to. Maybe we will make a trip or two then look at whether or not we need solar.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 26, 2025
