suprz's avatar
suprz
12 volt accessories and outlets
I will be adding some USB outlets in the cab area of my 2006 Ford E450. I will be putting one in the cup holder area, and would like to also put one on the passenger side lower dash valance ( for lack of a better name for it). However, I just checked and there seems to be a steel plate running the length Of The lower valance behind the plastic trim. Has anyone put an USB outlet in their coach on the passenger side if so how did you do it?
  • Like you, I also ran into metal behind the dash and dog house area where I wanted to install an outlet. The only solution is to find an area without the metal. It may not be the optimum location, but it usually ends up working out.
    I did see a surface mount USB that looked like a small puck with the outlets on the side. It attached with these small screws into the rigid plastic dash but I was concern they were a bit too small to stand up to repeated use. Another option is to get one of those flip down brackets so the USB is mounted horizontal under the dash and can be flipped down when needed.
    You may want to just search online for vehicle usb outlets and sooner or later one may pop up that would work.
  • shastagary wrote:
    how about something like this Multi-Port Car Charger
    That's a neat gadget, but I already have something similar. I'm looking to clean up the looks Of The cab and not have a tangle of cords around a single point. That's why I want to have separate USB outlets
  • You can get adapters that plug into 12V cigarette lighters and each one gives you two USB outlets. Work fine. No demolition needed. Of course the new HD trucks are overloaded with cig lighters, maybe 4 or 5 but maybe not so for a 2006.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,412 PostsLatest Activity: Jul 15, 2026
