EMD360's avatar
EMD360
12v outlets
Our 25b came with only 2 traditional 12v outlets in the coach. These are for the tv’s. It has usb outlets though. One over the rear bed and one at the dinette. Some time ago I changed the light fixture in the overcab bed to one with a usb outlet. But there is no 12v. I recently bought ultrasonic rodent repellers and wanted to plug one in centrally. It came with battery connectors so I cut those off and added a 12v plug. Then I removed the upper cabinet corner panel and tapped into the usb outlet wiring.
Somewhere I read about t-taps that don’t require cutting the wires. Unfortunately my drill bit made a ragged hole. I screwed the new 12v outlet in and I ended up having to cut a little more of the cabinet bottom to fit the new outlet next to the usb outlet.
I replaced the panel and I will probably leave the blemish on the cabinet bottom. Normally I have small plastic drawer sets up there and will not see it.
1 Reply
  • Bobbo's avatar
    Bobbo
    Explorer III
    My Airstream came with plenty of USB outlets, and precisely ZERO of the 12v outlets. I have added 2 of them, myself. I put one in the panel under my bed to plug in my CPAP machine. There was an unused pair of 12v wires there, so I used them. (They must have been there for other options.) I also put one under the dinette to plug in my laptop charger, or anything else. There were no spare 12v wires there, but there had been a sub-woofer there with 12v power. (It is now in the top of my closet at home for re-installation if I ever sell the trailer. Removing it tripled the storage space I had in that compartment, and we never listen to music.) I tapped into that circuit.
