LittleBill
Feb 21, 2022Explorer
2112 wrote:
Just read up of Fusion 360. First create an offset plane then use that as a reference for an angle plane. Offset plane sets the reference offset, angle plane sets the angle, build on the angle plane.
Yea that doesn't work in Fusion. well not directly, but I tried this initially, and failed, but got it now. you need to create an offset plane, then create a construction line, then create the angle plane based on the construction line, which reference the offset plane.
wow. that said I was also very close using a draft as well.
getting there.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
