Feb 21, 2022Explorer II
LittleBill wrote:Yea, I pointed that out to K & I. They had too much of a point as well, weakening it. Put a slight round on the tip to make it print better and for integrity.
the hose thread is also different then mine, hose thread doesn't have a taper and requires a washer, the original does not match hose thread at all.
No need for a washer. There won't be any pressure there, it's an open pipe. It would print better if you changed the washer flat to a chamfer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
