LittleBill
Feb 27, 2022Explorer
2112 wrote:
Hey, looks good. Did you use a helical revolve for the ramp?
How did it print?
Now you can take a moment to reflect on all you learned
No, its not a normal thread, and i struggle with threading still.
its an offset angle plane, using lines and 3 point arches.
I could not find a specific place to put the holes. googling showed this thing installed in about 50 different orientations, so it is what it is.
printed fine, supports are a bit terrible on petg, I have issues using tree supports, on my next print going to use standard supports to see if it will clean it up a bit better.
that said all the important sections printed perfect, and there is over a inch of rotation to lock it in, video below.
I have to add ribbing to the top, and some more fillets, but it seems fine. I will mail one out shortly to one gentlemen, see if there is any issues but should be good. hopefully there isn't much variance between fillers.
FOLKS YOU NEED TO SUPPORT YOUR HOSE'S USING THIS. I printed this literally at 100% strength for the ramp. You do risk breaking the water fill side, if extreme weight is placed on it. It was designed for a cap, not a hose. I take no responsibility if it breaks your water fill. I made the ramp 2x larger then the cap to spread out pressure, but there are still limits.
strongly recommended a swivel adapter of sort, so the hose doesn't cause a twisting action on the adapter.
My fill adapter on my rv is broken, this is why it moves, the fitting does not move at all once connected..
Video of it connecting
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
