Feb 28, 2022Explorer II
LittleBill wrote:I read this this morning and thought it couldn't be that difficult. So I read up on fusion sweeps and threads and yep, this would be that difficult. You can do custom cuts but didn't find examples of extruding a custom sweep profile on a surface. SO, you do what you have to do, and you did. You did a great work-around.
No, its not a normal thread, and i struggle with threading still.
its an offset angle plane, using lines and 3 point arches.
It took me about 20 minutes to create the below. A pitch of 8 TPI traveling 0.1875in vertically created a 67.5 degree tab. I created an identical sweep 180 degrees from the first. Just thought I'd share
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
