For all of you that have been following this thread, LittleBill has been working on this for a while and I have completed the Beta test of the 3d printed water fill adapter.
Now for the disclaimer and to hopefully stay within the Forum Rules.
I have no financial stake in this and no one has twisted my arm to make any remarks that are not my mine.
These are the adapters.
They seemed well made and robust.
This is my fill spout
This is installed,I had to wiggle a bit to get it seated,just line up tabs,turn about 1/4 turn clockwise and it seated tight on the fill spout,no wiggle at all.
The hose threads fit the hose end perfect
But as I have done on my city water inlet I put a 90 degree fitting on to decrease the strain on the inlet. With a quick dis connect that I use on all my hoses,filter and regulator.
And this is installed
When filled the water comes out the holes,not a big spray and much nicer than the hose thing I used before.
This is so much better than the other types of devices that I have used to fill my gravity fill fresh water tank,it filled faster with less mess,just unhook and stow it away,one of the best purchases that I have made for my RV.
Thanks LittleBill for all your hard work!
