rrwantr's avatar
rrwantr
7 feet between 6 volt batteries in series?
Looking to upgrade to two 6 volts. Can't fit a double box in the area my single 12 volt is. Would it be ok to locate one on one side of the camper and one on the other with the batteries wired in series appropriately. So there'd be 12" hot to the first, about 8' between the negative and positive of the 2 batteries, and then 8' return from the negative of the 2nd battery.
And would be looking to put on portable solar.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
