4x4van
Mar 03, 2016Explorer III
rexlion wrote:
The wind would push hard enough on the door to make the ball go backward in the groove, past the narrow spot, and pop out.
Sounds like your hold-back is installed incorrectly. It should be installed so that the arm swings up/down, not side/side. If installed correctly, the arm must be lifted up in order to go past the narrow spot and pop out. I have the same type (although the metal version), and it is impossible for the wind to unlatch it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
