rexlion's avatar
rexlion
a better door hold-back device?
To hold the trailer door open, my trailer came with one of the plastic knobs that sort of snaps into a groove. It doesn't hold the door securely in a strong, swirling wind. The wind would push hard enough on the door to make the ball go backward in the groove, past the narrow spot, and pop out. I am tired of having it slam shut (or hit me) when I least expect it.
I've had experience with the metal t-shaped hold backs, and they can detach in a strong wind as well. So I don't want one of those.
Can anyone suggest a more secure hold-back device that won't let loose in high wind, yet is easy to engage/disengage with one hand?
  • I use a long loop of nylon cord/string. Loop it around the cab door handle, then over the latch or handle of the open coach door.
  • Chris Bryant wrote:
    I really like the aluminum positive catch style like this one
    usually used on horse trailers and commercial rigs.
    Positive latch, easy to unlatch, and will not break.
    That's a good strong hold back, and Eastern Marine has them for $5.99. Someone else may have them cheaper, but I didn't find them in a quick price check...
  • I really like the aluminum positive catch style like this one
  • rockhillmanor wrote:
    I switched mine out to a ball and snap holder. Never came open again even in high winds. AND bonus was it was much easier to latch and unlatch and close and plastic so it didn't scratch the RV. Camping stores carry it.
    X2
  • I switched mine out to a ball and snap holder. Never came open again even in high winds. AND bonus was it was much easier to latch and unlatch and close and plastic so it didn't scratch the RV. Camping stores carry it.
  • I have the C clip style. First, I got the metal female end (instead of the plastic). They work MUCH better. If for some reason the clip won't hold, I use a bungee cord. Don't usually try to keep the door open in high winds - just open and close as needed.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Oct 12, 2025
