Old-Biscuit
Mar 20, 2018Explorer III
IF you have a switch in outside compartment for electric then you have a Suburban Water Heater.
120V AC from circuit breaker goes directly to that switch and then to/thru the set of t-stats and then to the electric element (Direct 120V AC circuit)
You just need to locate/ID the 120V AC feed....circuit breaker and then install a new 120V AC Lighted On/Off Switch in series with existing OEM AC Switch.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
