SoundGuy
Mar 21, 2018Explorer
FF/PM wrote:
What kind of switch do I need? Do I run 110 to the switch, or is it a relay? This is in a 2015 Keystone Cougar. 30 amp, OEM system.
That your rig is wired with 30 amp main service is irrelevant, nor do you need a relay. Any 120 vac switch will do - I bought this one at Home Depot which had a large, easy to use switch & an indicator light and mounted it in a surface mount box which I placed in an easy to reach location just above where the water heater was located in our K-Z Spree. I wired it into the 120 vac feeding the water heater so when switched on the light would indicate power was being fed to the water heater's electric element.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
