FF_PMExplorerMar 20, 2018Add a 110v switch for water heaterI have a water heater that has its 110 switch outside. I want to add a switch inside, leaving the outside switch "on". The power inverter is directly below the central control panel. I'm thinking I ca...Show More
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Atwood water heater problemSwitching toiletsWater Heater Replacement RecommendationsWater Heater Leak on start up.
